LabVIEW 8.2 does not recognize the .lvm files older version did
Labview 8.2 does not recognize the .lvm files.  I can run my old program, but I can not open the .lvm files it creates or any older files that I had.
(2,632 Views)
Can you please elaborate?  The more you can tell this community, the more we can help.
I just created a VI that wrote a LVM file in 7.1, and I was able to successfully read the same LVM in LabVIEW 8.2.  I was also able to run the "old" program in LabVIEW 8.2 and read from that file in LabVIEW 8.2.  Which version of LabVIEW was used to create the "old VI" ?  Are you using the same "Read from LabVIEW measurements file" that worked in the "old" version?  I think you just need to double check your read from LVM file settings to make sure they match the specifications of the write to LVM.
Cheers,
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(2,614 Views)
