The CWGraph3D axis loose fit behavior
The CWGraph3D control's X,Y and Z axis behave as if they have a loose fit.  That is, they do not make their axis minimum and maximum limits correspond to what their data values are but instead round the minimum down and maximum up to some integer increment.  This often leaves significant empty space along the axis.  LabVIEW's graph has a loose fit property to turn off this behavior.  Does such a property exist for the CWGraph3D control ?
Steve
(2,584 Views)
Steve-
I do not beleive that there is any property node equalivent to the Loose Fit option available on teh waveform graph.
(2,568 Views)
