Changes to Code which the IDE "forgets"
I've come across some situations where I've made changes to a group of VIs or Objects and when it comes to close LabVIEW, LV conveniently forgets that certain things have changed.  I say forget, but that's being nice because LV never seems to have known about the changes in the first place.  If I rely on LV telling me what to save when closing a project, it often ends in tears.  Re-loading the code can be broken as a result, or even worse, it might work but intriduce some hard-to-find bugs.  Of course the solution would be to save rigorously, but I still think LV should try to keep things intact if possible.
  • FIFO Reference settings on FPGA (Read, Write, Clear) settings are completely ignored.  LV claims things have not changed, but they have.
  • Changes to many LVOOP (.lvclass) properties.  Again LV claims they have not changed, but they have.
Do others have more examples?  Each time I get bitten by this behaviour I rage shortly but just get back to work.  If we can try to get a list together, maybe it'll be enough to slap an idea on the Idea Exchange.
I'm using LV 2015,s o maybe things are better in the current versions?
Message 1 of 1
(2,421 Views)
