Problem installing LabVIEW Control Design Toolkit
Hi!
I found an interesting example: "Simulating a wind turbine"
But when I tried to open it I can´t because I dont have LabVIEW Control Design Toolkit
I downloaded the evaluate version and installed it following the instructions but after that procces, when I try to open the program it doesnt find Sim halt.vi
How can I solve this? Shall I dowload another toolkit for this example or what is wrong in my computer?
Thanks for your help
Message 1 of 10
(6,679 Views)
Did you search the forum? Have a look here.
Message 2 of 10
(6,664 Views)
Yes men, but it doesnt solve my problem
Message 3 of 10
(6,642 Views)
Attach the example here of "Simulating a wind turbine" and I will try to open it. I have Control and Simulation design module 2016. If it works, then you would know what it needs.
Message 4 of 10
(6,631 Views)
Thanks for your response CataM, I have attached you the example
Message 5 of 10
(6,629 Views)
Message 6 of 10
(6,625 Views)
Hi again
Thanks for your time Cata, I'll probe with the link that you send me, but I think I have it installed, I have attached an image of NI license manager in which you can see that Control and design toolkit appears
Message 7 of 10
(6,623 Views)
Do you have Control and Simulation desgin module 2017 ? If so, then you nedd some other software because you already have the latest version. It works with 2016 module as well because that is the version I have.
Message 8 of 10
(6,620 Views)
I found the solution.
If someone have the same error, after installing the Control and Simulation desgin module 2017 I was trying to open the example with Labview 2017 64 bits version and it said that I haven't installed the toolkit but If you probe 32 bits version it works properly.
Message 9 of 10
(6,599 Views)
I have already LabVIEW 32-bit version and control design module 2017, but I'm still getting Sim halt.vi error.
and also when I open my QNET quick start program by ignoring the error it says that your control module is not installed
Message 10 of 10
(6,272 Views)
