Changing Application Font sizes of Exe using ini file
@bseguin wrote:
NXG is way to high level. it removes every low level functionality that we can have. NXG is made for people that just want to do a quick soft to measure some stuff.
In my case, NXG is not a solution... if this is the future of LabVIEW, I<ll move away from it.
Benoit
I didn't mention NXG as a solution. At the moment NXG still being developed not it's not nearly done. The problems with (lack of) Unicode is one of the reasons NI started over. NXG will get low level control, or nobody will use it. At the moment it's only useful in corner cases: simple DAQ or Web VIs.
NXG will replace CG.
Message 11 of 11
(536 Views)
