Changing Controls
Hi guys ,
Can you please suggest me , how to change controls from normal style to silver style by selecting on the whole?
Because i have to replace each n  every control by the replace option?
Boldness has genius, power and magic in it!'
Message 1 of 8
(4,120 Views)
http://digital.ni.com/public.nsf/allkb/2827D5777B012B2886256F2A0073F71A
Unfortunately not, as you can see here.
Chris
Message 2 of 8
(4,106 Views)
Ya i have tried , I was just wondering whether is there any other way.
Message 3 of 8
(4,097 Views)
A faster way of replacing controls is using the quick drop shortcut.
https://www.ni.com/en/support/documentation/supplemental/08/boost-labview-productivity-with-quick-dr...
Message 4 of 8
(4,087 Views)
Accepted by MaveenD
It seems that you can replace multiple controls using the quick drop method. Just select the controls you want to replace, press Ctrl + Space to open quick drop, then select the control you want to use.
Message 5 of 8
(4,076 Views)
A long time ago I made a utility to do that.  Never used it much.  Can't remember how far I got in debugging it.  Have fun.
Message 6 of 8
(4,059 Views)
nice idea
Message 7 of 8
(4,029 Views)
as already mentioned, the Quick Drop method seams to be the best solution for you.
Boost Productivity with Quick Drop
The only alternative is to replace each button individually.
Is this a solution for your problem?
Do you have other questions?
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
Message 8 of 8
(4,015 Views)
