Changing directory for Saved data within program?
Currently, I have the save data function which is shown in the bottom of the screenshot attached. It saves only in the default directory and only if that directory exists. I was wondering how to get a pop-up box to change the directory it saves to or modify this on the fly. Is this possible? What is the best solution for this.
(3,257 Views)
Hi suspencef,
you can use the file dialog for that or leave the path connector unwired then the file dialog also comes up.
EmilS
EmilS
(3,249 Views)
Thanks a lot.
(3,225 Views)
