Problem downloading Labview 8.6 from NI FTP
 Somebody successed to download evaluation version of Labview 8.6 from NI ftp:
    https://lumen.ni.com/nicif/us/lveval/content.xhtml
I get an error at about 250 Mbyte from starting the downloading. 😞
Michael.
P.S
    Is there any mirror?
Message Edited by mishklyar on 10-12-2008 10:37 AM
_________________________________________________________________________________________________
LV 8.2 at Windows & Linux
(3,364 Views)
I, and many others, have successfully downloaded it. Most likely just a connection glitch. How many times have you tried? What kind of connection do you have? Are you using an ftp client, or are you trying to use a browser?
(3,360 Views)
No problems here, took about 30 minutes for the full file.
Try the following:
  • Clear the browser cache.
  • Make sure there is enough disk space where the temporary files are located (and in the target folder).
  • Try a different browser.
  • Try a real ftp client (you would need to know the correct username and password, which shouldn't be hard to find ;)).
  • Check your HD for errors.
What kind of internet connection do you have?
(3,355 Views)
I was using "internet explorer" browser.The connection is fast, it promised to be finished within an hour.
Now will try an ftp client
(3,337 Views)
