Changing graph positions programmability
Is there a way to change graphs position based on a state of your VI? For instance: I want to switch two charts based on a test type. The charts are different sizes. I know I can just wire the charts oppositely in my code but what changes do I need to make for the labels and such? Are there property nodes to change the label of charts?
(3,116 Views)
Accepted by glskinner
So far as I know the VI must be in edit mode to change the label name. You can use property nodes to read and write the actual position your chart currently is and to define where you wish it to be. This can happen during run time. If you want to programmatically change the names of charts you have to have something like a second VI that runs and modifies your main VI when it is closed and changes the names there through property nodes and such. It's a huge pain (though fun). 😛
You can even stack the charts on top of each other and just change which is visible (this is probably the easiest way to do what you describe). Also another thing you could do maybe is use a string indicator to hold your chart name.
Anyways hope this helps!
(3,097 Views)
While you must be in edit mode to change a label name, the caption name can be changed at run-time and was designed for that purpose.  Thus, the simplest way to do what you want to do is to show the captions, hide the labels, and, at run time, change the captions and the contents of the graphs.  You will need to use property nodes to change the captions.  To show captions, right-click the graph and select Visible Items»Caption.
(3,063 Views)
