Changing language of LabView controls?
I just need confirmation. If LabView controls, like a graph, have a context menu then this context menu will be first in the language of the LabView IDE it was used with. If I build an application, then the builder includes the LabView RTE. This will also be the same language version as the IDE.
Now , if I wanted to change the context menu language let's say to french, would it be sufficient for the user just to install a french version of the RTE? Is this correct?
(4,131 Views)
(4,127 Views)
You could you Import/Export strings from the menu bar to import other language text to the control on the FP.
A programatic code for this is possible.
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
(4,122 Views)
Accepted by MaSta
muks wrote:
Will this be of use?
Yes, thanks. So another locale of the RTE would overwrite the one we supply in our installer and then the user would have the context menu in his language. Fine!
(4,111 Views)
