Changing layer order of front panel controls
Hi, is it possible to programmatically change the layer order of front panel
controls. I want to send a control to the back on my main window through a
property node in a sub vi, is this possible??? Cheers, Tom.
Message 1 of 11
(25,697 Views)
Actually, I don't think you can do this. Changing the layering requires that the VI be in edit mode, which it is not when you are running the VI.
J.R. Allen
Message 2 of 11
(25,697 Views)
How can I change the layering in Edit Mode? I can't seem to find a "send to back" or "bring to front" command in any menu.
Message 3 of 11
(25,697 Views)
The revolving arrows, to the right of align and distribute in the
toolbar allow for what you want. The key equivalents are something like
ctl-j and ctl-k for moving one step and ctl-shift moves all the way.
Greg McKaskle
Message 4 of 11
(25,697 Views)
You need to hit the button that has the blue and yellow buttons on it.
For more info about this you can look here:
https://www.ni.com/docs/en-US/bundle/labview/page/reordering-objects.html
Message 5 of 11
(20,686 Views)
Answering an eleven year old thread?
Message 6 of 11
(20,665 Views)
Yep.  I figured if I could end up here after googling "how to change layers in labvew" others will end up here too.  Answering unfinished threads... this is my contribution to posterity.
Message 7 of 11
(20,631 Views)
It helped me. Thanks!
Message 8 of 11
(19,730 Views)
Thanks. It helped me too.
Message 9 of 11
(13,074 Views)
   To:           Chon.Mech -   Thanks for taking the time to answer. That answer was the best, even if 10 years later...   Sadly, "bring to front", which is a pretty well known concept, is not mentioned in the NI help system.
Message 10 of 11
(9,763 Views)
