Changing the Size of generated graph in excel report generation toolkit
Hi, i am trying to build a report generation vi for my Structural health monitoring system in which i need to export 3 graphs in to an excel report. The idea is to have the report on a single page, but when i paste them along with the ceiling and pillar deviation percentages, the report just exceeds the page limit. I wanted to know whether one can change the size of the graphs in excel? One can do it in word(tried that), but i dont want to use the bookmark option as it intend to put this up as a webservice in the next step. I am using LabVIEW 2009 Thanks.
LabVIEW 8.2,8.6,2009...still learning 😛
(3,006 Views)
I haven't tried this myself, but looking through the report generation toolkit the "Excel format image VI" (in the Excel specific tab of the Report Genertaion window) looks to be the one you are after. The help entry for the VI says to: "Use this VI to format any type of image in a worksheet, including front panel images, images from a file, and graphs"
Hopefully this will help.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(2,981 Views)
Hi wond3rboy,
You can use the Excel Insert Graph.vi in order to have the ability of changing the graph size.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(2,965 Views)
