Changing the dimensions of a 3D surface plot
@moi maker wrote:
I'm having the same problem. (Or what I think is the same problem...)
I want the x and y axes on a 3D graph to have the same scale, but I can't just have a fixed scale, I want it to vary with the size of the data.
There is a control for whether to autoscale the axes, but I would like a control which sets the scale of an axis to a particlular value depending on some input data.
Not sure if it's possible...
Did you try it?
Ben
Message 11 of 13
(721 Views)
Thanks Ben, I downloaded your package, but I can't get it working.
I only need the "Set Axis Range.VI", but I'm not sure what to wire to the x, y and z inputs. It wants a 2D array for each....
I am making a 3D plot from z data only, and want the x and y axes to grow or shrink in length to fit the size of this data. Basically, I'm plotting greysacale values from an image as a 3D surface, and I want to maintain the aspect ratio of the image.
Message 12 of 13
(711 Views)
For others trying to plot a 2D contour from z data with the x and y axes corresponding to real space:
I can't remember if I made or downloaded this VI.... but it works! 😛
Just wire the z data to the regular 3D surface VI, then the same data to this VI along with the 3D graph reference.
Message 13 of 13
(649 Views)
