Changing the interval of increment/decrement buttons?
I have an array of doubles as seen here:
The increment/decrement buttons change the values by a factor of 1. Is it possible to bring that down to 0.001 for each one?
(2,222 Views)
Accepted by danthecoffeecan
Yes, right-click, open properties.  On the Data Entry tab there is an Increment parameter.
Keep in mind that if you put your cursor in the control your keyboard's left/right arrow keys can change the resolution and up/down arrows will change the number based on that.  This trick works better if you change precision type to "Digits of Precision" and disable "Hide trailing zeroes" in the Display Format tab.
(2,214 Views)
Thank you!
(2,194 Views)
