07-30-2007 03:28 PM
07-31-2007
06:41 PM
- last edited on
08-20-2025
08:16 AM
by
Content Cleaner
Hi Alex,
Only one gain can be selected for all the channels on the SCXI-1100. In the manual in section 3-10 (page 56 of the pdf), the picture shows that the inputs are first multiplexed and then they are amplified by the gain you set. The gain can be set by changing the range in the DAQ Assistant or by using a DAQmx Channel Property Node in Labview. With the DAQmx Channel Property Node, the property can be found under the following: Analog Input » General Properties » Advanced » Gain » Gain Value.
Hope this helps,
Paul C.
