Character name/description from Character symbol
This may sound a bit unusual, but probably someone already did this.
Is there any way to show the description or name of a character that was just typed in the String control?
So for example, if I type " ", the description is "<space>", and if I type "," then the description is "comma".
Yes, I can build this through a case structure on my own, but if it's possible to fetch from some existing database (like the Char mapping), then it's better. Because on my own, I may miss some character and after all, it's a lengthy process.
Thanks and Regards,
Vaibhav
(3,297 Views)
Accepted by Vaibhav
Hi Vaibhav,
use a lookup table with the U8 value of the char as pointer into the table.
You can create that "table" as 1D array of strings - which is much easier to create when using a usual text editor to create a txt file and reading the file using ReadSpreadsheetFile…
(3,281 Views)
Here's a table which may give you a start
http://www.ascii.cl/htmlcodes.htm
MC
(3,258 Views)
Hi GerdW and MC,
Thanks.
I found my complete table on the http://www.theasciicode.com.ar/ page.
It's a pity I cannot use the UNICODE characters in LabVIEW, alongwith other simple characters. I must change the whole text's font to Symbol, for example to use Greek letters in between other text controls (like Enum or String or Tree View), as I asked in another thread. That would have been really good.
Vaibhav
(3,234 Views)
Be careful what ASCII table you use.  The extended characters (decimal 128 and above) can vary.
Here is a different table that I would say is much more commonly used.  http://www.cheat-sheets.org/saved-copy/ascii_a4.pdf and matches what is showing up on my PC.
(3,225 Views)
Thanks. Already saved.
Actually, I used that page that I mentioned only because of the readily available descriptions. Will update the list with more time at hand, and use the more reliable source.
Vaibhav
(3,221 Views)
