Chart/Graph Update Mode Grayed out
I need to change the update mode for a XY Graph to Sweep Mode but the combo box for Update Mode is grayed out, any idea why?.. Thanks
Message 1 of 8
(7,778 Views)
It's because XY graph doesn't support update mode feature.
Message 2 of 8
(7,775 Views)
I've been trying with all of the chart/graphs and still the same...
Message 3 of 8
(7,760 Views)
Accepted by topic author Edu9
It's available for "Waveform Chart".  See help:
    • Update mode—Update mode of the chart. You also can use the Update Mode property to change the update mode of a chart programmatically.
Message 4 of 8
(7,749 Views)
Thank you!
Message 5 of 8
(7,743 Views)
Minitab version 19.  The graph options are greyed out.  Unable to update graphs.
Message 6 of 8
(5,693 Views)
Graph options greyed out
Message 7 of 8
(5,690 Views)
You are replying into a 5 year old thread.
And you haven't given any information as to what your problem is.
And what does minitab 19 have to do with this?
I suggest you create a new thread, explain your problem clearly, and attach any VI you have that is giving you a problem.
Message 8 of 8
(5,676 Views)
