Chart - problem with stack
Ive got 3 problems with stack plots:
1. In the legend, the first value of table is the last one, why?
2. Always when i remove one value(in this case i turn off button), the last chart is remove
3. When I turn off the second button(rest is on), the plot name in legend is doubled.
Does anyone have an idea what i can do with this?
thanks for any answers.
(4,321 Views)
Propery nodes execute top to bottom, so you first need to set the active plot and then the name, not the other way around. Change the order of the two properties.
(sorry, I haven't looked at the rest of your code)
(4,297 Views)
Ok thanks, that was the one problem. The second is:
I dont know how to off one plot from the middle of stack.
I belive the problem is in this part(attached png), because when i off one button, the number of total is decrement. But i still have no idea what to do to avoid it.
(4,284 Views)
Try something like this:
(4,264 Views)
Nope, still the same.
I have added case structure to show the problem.
nr. chart - value
0 - 0
1 - 1
2 - 2
3 - 3
for example when I turn off button nr 2, i lost plot nr 3... In the legend it looks alright
That's so annoying...
(4,243 Views)
Accepted by Mirasoul
Well, you simply need to code it differently.
Try this:
(4,237 Views)
That`s what I wanted. Thanks a lot!
(4,234 Views)
