Chart-problem
Hello!
We have a problem that we get only one curve but we want to have one curve/signal. We have asked about this before but now we send an attached VI so the problem can be seen easier.
We took out a bit of our program. The signals are acquired from a CAN-bus from the beginning (data). So you can not see any signal from the "X8" and "X6" but one can see the problem better...
So we want it to be as (in this case, it could be moore than two signals ...) two straight curves on the values 10 and 11 (in this case because you can not see any value from the X6 and X8 as we have).
Anyone got a tip?
Best regards.
(2,722 Views)
I am not sure that this suggestion is the answer that you want but see please the attached vi.
Regards
TN
(2,714 Views)
