Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
how to get transfer function back out simulation loop
mcgoo32
Member
03-22-2005
05:37 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I'm using the control toolbox and the simulation toolbox on labview 7.1
I use the convert transfer function to simulation block to get the data inside the simulation loop
the problem is that i cannot export the transfer functin data outside the simulation loop.
i can get graph data out using a collector, but not transfer function data
can anyone help please?
an example would be extremely helpful also if possible
cheers
Daniel
0
Kudos
Message
1
of 2
(2,820 Views)
Reply
Re: how to get transfer function back out simulation loop
Lilly N
NI Employee (retired)
04-01-2005
04:26 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Daniel,
It would be great if you could post some code to show the issue, then I can have a look into why you are having trouble getting the transfer function out of the simulation loop.
Lilly
0
Kudos
Message
2
of 2
(2,796 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
