Chart showing real time versus temperature
How big is the chart? How do you have the x axis formatted? You can certainly display more than one label but you would be limited by the size of the text in the label.
Message 11 of 16
(1,138 Views)
The chart is about 15cm wide but I haven't managed to find an option that shows more than one data label on the x-axis.  I can do it on a graph but not a chart.
Message 12 of 16
(1,136 Views)
The formatting options for the chart is the same as for a graph. The defaults are different, though. What have you done with the x axis properties as far as visible lines, etc.
Message 13 of 16
(1,130 Views)
Thanks for helping out.  I could select "major and minor" tick marks in the graph option but in the chart option there is nothing on the x-axis which allows you to put lines on the chart.  At least as far as I can see.
Message 14 of 16
(1,119 Views)
It's there. I'm posting from my phone so I can't look it up for you. Post an image of the properties page so I can refresh my memory, please.
Message 15 of 16
(1,111 Views)
Unfortunately I am not near a computer with LabView on it and I won't be so until Monday.  If you get a chance before then to have a look that would be great.  Otherwise I'll put an image up on Monday.
Message 16 of 16
(1,106 Views)
