Chart with Time and Date on x-axis
Besides the guide here : https://decibel.ni.com/content/docs/DOC-8097
is there any other new method that can be implemented using LabVIEW 2012?
(2,929 Views)
The reason I'm asking is because this method shows extra values after seconds (as shown in the red circle)
(2,928 Views)
Right click on the chart, select properties, then display format, and then set up the X axis for 2 digits.
-AK2DM
(2,922 Views)
@AnalogKid2DigitalMan wrote:
Right click on the chart, select properties, then display format, and then set up the X axis for 2 digits.Custom time format/ vice system time and 0 digits the default system time usually includes %.3u (millisecond resolution)
-AK2DM
(2,917 Views)
I don't really understand the second method you suggest but I tried the first and set the digit to '0' and it works. Thanks^^
(2,891 Views)
