Error 1 during Build of exe
I have a program that I regularly build exe code from.  In the recent few weeks I have seen increasing errors during build.  Previously a save-all fixes the issue.  The compiler complains of Error 1 for a random vi.  The file identified changes and none the files have recently been updated.   Using LabVIEW 2011 SP1 Professional.  Did a full reinstall of the NI products, no help.  Mass compile is no help.  Relocating to C:\... to minimize path length is no help.  Suggestions ?  - thanks
LV message.......
Error 1 occurred at C:\Program Files\National Instruments\LabVIEW 2011\instr.lib\rscmwws\Utility\rscmwws Reset.vi
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @. ========================= NI-488:  Command requires GPIB Controller to be Controller-In-Charge.
(3,034 Views)
Accepted by JordanG
I resolved the issue by setting the following build properties
 - disconnect type definitions
 - enable debugging
 - unselect SRS
reference Forums Post - LabVIEW Build errors
(3,030 Views)
