Check host VI is running?
Hello All,
I came across a situation where I need to check in RT VI that wheather my HOST VI is running or not? I have no Idea how to implement this.
I would appreciate your help for implementing this condition.
CLAD
Passionate for LabVIEW
Message 1 of 8
(3,916 Views)
What communications are you using between the RT and Host?
Message 2 of 8
(3,896 Views)
Let the host VI send timestamp to RT every second - heart beat.
If not receiveing heart beatfrom host, then it's down.
In addtion, RT can sync to the timestamp at the begining.
George Zou
Message 3 of 8
(3,867 Views)
I use ethernet (shared variable) for communication between RT and HOST.
CLAD
Message 4 of 8
(3,853 Views)
So do I need to compare time stamp sent from host with time stamp of RT? Or there is something direct indication I would get ?
CLAD
Message 5 of 8
(3,851 Views)
That's optional.  If the host is down, you won't get anything.
George Zou
Message 6 of 8
(3,849 Views)
No, you'd compare the timestamp you got from the last timestamp before that.  They should be different.  If they are the same, then it didn't update it.
Message 7 of 8
(3,840 Views)
I agree with the others that a simple timestamp shared variable would be the easiest.  Just create a loop that iterates about once a second and see if the value changed.  If it does, then your host is active.
Message 8 of 8
(3,819 Views)
