Check to see if a string is "close enough" to what is expected
@UliB wrote:
@paul_a_cardinale wrote:
@Eric1977 wrote:
@Eric1977 wrote:
for (i = 0; i<=n; i++) {
p[i] = i;
I am not used to Java programming (actually, I've never programmed in it before) but it's just a For Loop incrementing one digit to the p array, correct?
Here's the equivalent LabVIEW code:
Is there a '+1' missing between the control 'n' and the 'N' terminal of the for loop?
Yes.  Good catch.
Message 11 of 15
(424 Views)
Yes.  Good catch.
These off-by-one errors are very common, but fortunately typically easy to detect. 😄
Message 12 of 15
(416 Views)
It's like they always say; there are only two hard problems in computer science- cache invalidation, naming things, and off-by-one errors.
Message 13 of 15
(396 Views)
Hello Paul, could you please share the VI for LabVIEW 2020? I am working on something where this algorithm fits great.
Message 14 of 15
(75 Views)
