Circle Fit Example
Has anyone seen any good examples of fitting to a circle?
To make things clear:
Given a set of x,y points, return the centre and radius of a circle which best fits the data.
Many Thanks
Nick
(7,263 Views)
Accepted by niNickC
There's a VI called "Fitting on a Sphere VI" that can do what you want. You just need to use a value of zero for Z data points.
Cheers
(7,256 Views)
Did you do a Web search?  A number of algorithms are out there -- pick one that seems appropriate for your data set.
(7,254 Views)
Yea I did spot this and tried exactly what you said with no success. Then I looked again and realised I messed up. (Forgot about the displayed precision!)
.. yeah ...
Thanks though!
Nick
(7,238 Views)
http://lmgtfy.com/?q=circle+fit+algorithms
Yea just trying to save some dev time!
Nick
(7,236 Views)
Since you are interested in a LabVIEW solution, a forum search here would have immediately found many example of James's suggestion above.
For example look here
(7,177 Views)
