Citadel 5 database read traces problem, LabView 7.1
I have very strange problem which I cannot solve. I have taken database which have been logging data for 2 years ( Citadel 5) and tryed making statistical analysis with it. Problem occurs when trying reading traces in areas with data breaks ( data breaks occurred because of radio communication which have been breaking on times). When trying read traces in LabView 7.1 read trace goes to timeout and returns data with 0 elements. In MAX 3.1 when trying to export same portion of data with export to text same things happen:
Now, i thought first that database is corrupt or inaccessable however when i tryed doing same thing with LabView 2010 on same database (c/p) everything worked. My question would be:
1. Why is this happening?
2. Is there a way to fix it ?
Program works without problem when transfered to labview 2010. Database was created with tag engine in LabView 7.1.
Thanks in advance
(3,077 Views)
Hey Pumba,
Why don't you keep using LabVIEW 2010. Any reason of using LabVIEW 7.1?
(3,043 Views)
