Clarifications about the Measure Count in Config Measure Settings VI from KE26XX Series
Does the "Measure Count" in this VI tell me that the SMU will only take, let's say, one current measurement at a specified voltage value? So, If I set the Measure Count to 10, will the SMU display the average of the 10 measurements made?
(538 Views)
Hi user,
which VI are you talking about?
What does the manual of your device tell about this issue?
(520 Views)
I'm talking about the Measure Count here:
I might have forgotten to upload the Config Measure Settings VI in question, so, here's also the VI in question. Also, the device manual does not say anything about VI's, or operation with LabVIEW in general.
(487 Views)
Hi User,
You want to say the device (programming) manual does not explain the command SMUx.Measure.Count (with x denoting channel A or B)!? Really?
Spoiler
I just checked myself: the command is described in the manual!
(480 Views)
No, I meant to say that the manual did not mention anything about its VI's or LabVIEW in general. I don't know how to implement those commands in LabVIEW
(470 Views)
