Class Object Constant border black
I was wondering why the constant or control of a class object is sometimes black.  What does this mean?
Dan Shangraw, P.E.
(3,790 Views)
Control vs constant?
Ben
(3,769 Views)
They are both constants.
Dan Shangraw, P.E.
(3,758 Views)
No, I think they're both constants. At least in LV 2016 the control is flat, not 3D looking. I think the standard white border indicates that the constant has default values for all data, and the black border indicates non-default value(s).
(3,757 Views)
Accepted by ASTDan
The black border signifies that data has been saved in the constant (as opposed to just the normal default values for the constant). This occurs when you create a constant from a Control that contained data from a previous execution of a SubVI, for example.  So it means be aware you are not starting from scratch! (this may of course be the desired situation).
(3,738 Views)
 Â¯\_(ツ)_/¯
(3,695 Views)
