Clear a combobox dynamically
Ok I know this has been asked before but all the answers are not working for me, so I ask again
My Vi requires a combobox to be used mulitple times with different values in. It is therefore created dynamically.
This means I have to clear the contents of the combobox before loading the next values.
I seemed to have misunderstood a previous declared solution.
I tried the method of creating a ref to the combobox, then a control ref from that, then linking that to a combo box property node and clearing the values string[] and value.
However I must be creating the control reference incorrectly as it is zero and I get a runtime error.
To get a reference I have to set it from the combobox reference then it runs but does not clear the combobox.
Any help would be appreciated.
Jessica
(1,116 Views)
Accepted by jessica_kh
Hi Jessica,
why do you need an additional reference control and a local?
This one works for me:
(1,100 Views)
