Clear or Reset Network Published Shared Variable's
I made an Array of Clusters as a NPSV and while testing I accidently wrote too many elements.  After I fixed it I can't get the extra elements to go away.  Is there a way to clear the data.
(1,255 Views)
If you write a smaller array new reads don't return fewer elements??
~ Helping pave the path to long-term living and thriving in space. ~
(1,229 Views)
Nope, I've tried writing an empty array and reading a subset and writing that back, but if I read the array it has over 100 elements with values and I only need 24.
(1,222 Views)
Ideally I'd like to default them at the start of each test programmatically.
(1,209 Views)
Overwriting it did work, I was getting an error trying to write a reset value even though the main data was writing.  I think it mite be because I had it set to single writer.
(1,161 Views)
