Help connecting a second dual channel syringe pump to existing code.
Hi everyone,
I am currently working on connecting a second dual channel syringe pump to my existing LabVIEW code. In my code, I am using the communication settings [x] to control my pump (ej channel 1, channel 2, single pump etc.). I want to connect a second pump by adding a COM port, baud rate, [x], and mode. I am new to LabVIEW and I don't know how to connect a new communication setting to my existing code. Can someone please help me? I have been able to get both pumps to work at the same time by opening the same script in two windows and using a different COM port in each window. However, my goal is to be able to control both pumps from one window.
Any help would be greatly appreciated.
(1,177 Views)
First you should be aware of LabVIEW Basics to understand the existing Module and Modify to adopt additional UUT/Device.
You can duplicate the cases (Initialize COM1,Start COM1,Send SettingsCOM1. StopCOM1,PauseCOM1,etc., to COM2 as well)
Add the Front panel elements and Buttons for the New UUT and Handle the button events to call the additional COMPORT device
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,171 Views)
Thanks for your fast response. I have already tried that, but the problem is that once I duplicate the whole module and connect it to the loop it would run but both pumps won't work.
(1,168 Views)
You cannot just duplicate the whole loop, handle the cases and Events  inside the Loop.
1.Edit the State Typedef and add new States.
2.Add cases for the new States.
3.Add Front panel Elements for additional Device.
4. Handle events for new Front panel Buttons.
Try this and share the modified code here, so that others can guide you if any issues on the modified one.
(1,163 Views)
what exactly do you mean by Edit the State Typedef and add new States? im kinda confused.
(1,150 Views)
okay,
so this is what i have so far.
(1,101 Views)
