Database / "Functionality is not supported" error
Hello. My task is to reproduce an example database (Database test.7z). The first task is to write new data. But an error occurs.
(1,744 Views)
I'm guessing it's something like the added [] that's causing some invalid request. Try to run the generated SQL directly in the DB to see if it works.
Qestit Systems
Certified-LabVIEW-Developer
(1,666 Views)
