Clearing a multicolumn box
I am writing strings to a multicolumn textbox and at some points in my
program, I would like to be able to clear the whole box and start over. Is
there any way to programatically do that ?
Thanks !
/Soren
(2,996 Views)
You can try to write an empty array the Item Names property.
Raymond
(2,996 Views)
Thanks, that cleares the tables for text, but I actually need to clear them
for color as well. Any ideas on that as well?
TIA
- Soren
"RayE111" wrote in message
news:20021113204153.28577.00000018@mb-cm.aol.com...
> Raymond
(2,996 Views)
Soren,
To set the background color of a multicolumn listbox programatically, just use the CellBG property node.
The attached examples shows how to use it.
If you want to change the text color, use the CellFG property.
Zvezdana S.
(2,996 Views)
