Clearing variables between runs
Hello
I'm pretty new to LABVIEW.
When I run the VI multiple times it sometimes clears the output fields (such as an array or a string) and sometimes keeps results from previous runs.
How can I clear the variables between runs?
Thanks in advance
Yuri
(5,773 Views)
If you show some code, we can tell you. It all depends on how you wrote your application.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,771 Views)
Accepted by iurik
@iurik wrote:
Hello
Thanks in advance
Yuri
Multiple ways
1.You can  initialize values before every run
2.you can use ReInitialize all to default (Invoke Node)
Its better to share code for clear understanding
(5,767 Views)
thanks for your help,
the initialization of the variable did the trick
(5,752 Views)
