Click on Labels not generate event
Hello everyone,
I would like to generate an event when a user click on the label of a Boolean control.
I often have clients who try to click on the text of the control rather than the image of the control itself.
Normally, we can simply do this by create a mouse down event on the control.
The problem that I face is that my control is a strict type def.
I discovered that, for labview 2012 (maybe for others), the label and the caption does not belong to the control if the control is a type def.
i.e. labview will not fire an event (mouse in / mouse down / ...)  on the label (or caption) if the control is a type def (or strict type def)
I was wondering if something clever can be done to fix this.
I have already considered to put a transparent control on the top of my label, but I was wondering if something "cleaner" can be achieved.
I am currently working on Labview 2012. v12.0f3
Windows10
Nick
I do apology if this topic is already created, I have tried to look on the forum before posting.
I have also tried to look in bugs registry. But I didn't find anything related to my problem.
(4,216 Views)
Accepted by Nicolas.P
Hi Nicolas,
use the boolean text!
It is part of the control and it will react on mouse clicks on the boolean text too…
(4,210 Views)
@GerdW wrote:
Hi Nicolas,
To expand a bit on this, hide the label on the front panel and turn on the Boolean text.
Bill
CLD
(Mid-Level minion.)
(4,171 Views)
Thanks a lot to both of you for the quick solution.
Best
Nick
(4,143 Views)
