Client does not have access to specified VI: license issue?
I'm trying to connect remotely to a vi and think that my configurations on both client and server are correct. When trying to connect using both the labview remote panel and the web-enabled browser, this message appears: "Client does not have access to specified VI". An excerpt from the www.log files shows:
"GET /lizard_gui0v5.htm HTTP/1.1" 200 971
FPP ConnAllowed - - derekm (***.***.15.100) Total licenses checked out = 1
FPP VIReqDenied VIAccessDenied "C:\Documents and Settings\Administrator\Desktop\labview\lizard_gui0v5.vi" derekm (***.***.15.100)
FPP ConnClosed - - derekm (***.***.15.100)
Is this a license issue, or am I missing something obvious?
(3,135 Views)
Try going under the host computer in LabVIEW and under Tools>>Options>>WebServer:Visible VIs make sure that you have "allow access" checkbox checked and then place a "*" in the field and add it. This will allow access to all vi's. The other issue could be your IT group not allowing access maybe because of a firewall or if you are using XP the windows firewall could be on. Can you ping the address?? Maybe try and setup some kind of TCP/IP or datasocket test between the two computers. This might isolate your issues. Let me know what you find. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,118 Views)
Success: Under the visible VIs option I added the "*" character as suggested, and now have access. I previously only had the top-level VI added, using it's full directory path name. I assumed that you just needed to add the top-level VI.
I also note that when connecting to the server from the client machine (using the remote server and not the web-enabled browser), you just need to add the name of the top-level VI, and not the full path to it. This is something that I think was also causing problems.
Thanks for the quick response on this!
(3,096 Views)
