Clock generation using 6674T
I have a NI 6674T timing module where i want to generate a 100MHz continuous signal instead of Pulsed signal.
Is there any configuration for this, if any please let me know.
(1,106 Views)
PXIe-6674T supports DDS generation from below 1Hz to 1GHz. See shipping examples at Help >> Find Examples >> Hardware Input and Output >> Timing and Synchronization >> Signal-Based
https://tmesystems.net/
(1,051 Views)
Thanks for the response but there is no result of generating cw signal.
(1,011 Views)
Hi Shetti,
Please explain what you mean by "cw"/"continuous" vs. "pulsed" signal!
What do you really need?
(969 Views)
