Close Block Diagram and Front panel at the same time.
Hi there,
I think I remember closing both Block Diagram and Front Panel at the same time from the Block Diagram.
It was something like ctrl+alt+W, or alt+ Close Block diagram.
Unless I just dreamed that.
(I know its possible to close both if I close the Front panel)
My Channel: https://www.youtube.com/@LV_Lab
(2,719 Views)
File>Close VI
I don't think there is a predefined shortcut. You CAN add a custom menu shortcut from the options environment page.
I usually go the safe route though an Ctrl+E just to make sure my FP is in a sane location and size on the primary monitor. I've been bit too many times by coding buddies that tile windows or maximize them to close panels I can't see. And the "Enhanced Language™️" I use when backing out often encourages more attention to details like that.
*"Enhanced Language™️" usage may be prohibited by company policy. Review your HR Handbook on workplace conduct for employees.
(2,708 Views)
I also just use Ctrl+e followed by Ctrl+w.  Ctrl+e toggles between the Front Panel and the Block Diagram and Ctrl+w closes the window.  Also already stated, closing the Front Panel will also close the Block Diagram.
(2,691 Views)
I always forget about Ctrl+Shift+W, but it is a nice tool...
Closing a front panel (there) will also close the diagram.
(2,598 Views)
Yeah, I just found it playing around searching for the other (prob not existent) shortcut.
And now I use it now and then.
(2,593 Views)
