Close the caller of a subVi while the subVI runs
Hello, I have the following setup and a problem that I can't solve yet:
a Main VI with its user interface that dynamically calls subVIs.
One of those subVI calls another VI which has second User Interface that should keep running in parallel with the main User Interface while the caller VI is closed and the next dynamically called subVI runs.
How can I achieve that? Everytime I arrive at the point where my subVI that calls the second UI runs, the VI with the UI starts successfully but the caller VI is "stuck" and waits for my UI to be closed in order to go to the next dynamically called subVI.
If someone can help me it would be very very appreciated!
Message 1 of 11
(4,216 Views)
Hi cassaniti,
how are you calling your "subVIs"? Are you really calling them "dynamically" using VIServer methods?
(Mind to share an example VI or snippet?)
Message 2 of 11
(4,210 Views)
This is a snipped of the function that dynamically calls all the subVI. One of those subVI calls my second UI and remains stuck..
Message 3 of 11
(4,204 Views)
Hi cassaniti,
So what is different for this subVI when other subVIs don't get stuck?
Message 4 of 11
(4,197 Views)
that while the other subVI perform some kind of measurement and then they are done, while this subVI is needed in order to launch the second UI with some specific parameters...
Message 5 of 11
(4,183 Views)
Hi cassaniti,
then you must inspect this special subVI and not the calling MainVI.
Mind to share it along with your UI.vi?
Message 6 of 11
(4,156 Views)
Accepted by topic author cassaniti
The PNG image you posted shows a standard Call-by-Reference, which is just like a subVI call, in that it waits for the subVI to finish.   But it sounds like you want to do an Asynchronous Call By Reference (ACBR), which is a different thing.  Look in the example finder for some examples of ACBR; you want "Fire and Forget", not "Call and CXollect".
Message 7 of 11
(4,146 Views)
Block Diagram: Right-Click: Application Control -> Start Asynchronous Call
Message 8 of 11
(4,132 Views)
Thanks!! The Asynchronous Call is exactly what i needed. Specifically the "call and forget". I followed this example in order to do it:
http://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/acbr_call_and_forget/
Message 9 of 11
(4,124 Views)
One more little question: how can I programmatically close this second UI that I asynchronously opened through another subVI? I don't have its reference number but only the VI name... is that possible or do I have to somehow access the task manager and kill it?
Message 10 of 11
(4,120 Views)
