Closing excel
How do i close excel after creating a new spreadsheet using the report generation tool kit.
(3,071 Views)
I believe the method to use is "application.exit". You need use the Excel.application reference. If you use report generation VIs, then use Dispose Report.vi.
Joe
(3,071 Views)
Yes, you indeed used the Report generation toolkit. 🙂
(3,071 Views)
