Cluster Array Uninitialized Elements
I've attached the code modifying the array and the type def. Local variables are used to read the array and write it as it is passed into and out of this sub-vi.
Message 11 of 17
(2,307 Views)
I can reproduce the problem, but don't understand it. Very strange....
(even happens in edit mode!)
Message 12 of 17
(2,297 Views)
Accepted by topic author nsarrault
Ah! The problem seems to go away if you ungroup the cluster elements!
Message 13 of 17
(2,294 Views)
Thank you! That worked! I never would have guessed that the grouping caused that issue.
Message 14 of 17
(2,281 Views)
Never heard of it before. seems like a minor bug.
Message 15 of 17
(2,277 Views)
What version of LabVIEW are you using?  I did not see this error.  I'm curious if it is because I was using 2024Q3 and it was fixed between Q1 and Q3.
Message 16 of 17
(2,255 Views)
I'm using 2024 Q3 on this project.
Message 17 of 17
(2,239 Views)
