Cluster Icon with typedef is large?
I'm using LabVIEW 2010 on Windows XP SP3 and tyring out the new feature to display cluster constants as icons.  This is a great feature.  I like how small the icon is, it saves a lot of space on the block diagram.  Have you noticed that for type def clusters that the icon is a normal sized icon?  It's not the small icon for non-typedef cluster constants.  Is this expected behavior or a bug?  I've attached a code snippet illustrating the above.
Thanks.
(2,585 Views)
Expected behavior. See comments here on the design of the typedef'd icon.
Briefly, this is desirable behavior so the developer is able to create a recognizable custom icon for the Typedef.
(2,583 Views)
