Cluster Question
Is there a way to get the Label, Caption or Text of the control
that is clicked within the cluster?
Is it possible to disable a button within a cluster?
I have attached my small example that I am playing with.  If someone knows how to do these things, I would really appreciate the help.
Paul
(2,908 Views)
Event structure and property nodes should do it. I have modified your VI to show the possiblity. The modification is not complete and will cause operational problems as implemented, but will show how to access the information you want.
Lynn
(2,895 Views)
