Cluster Value Property is Wrong Type
Why is the Value output from the property node a variant instead of a cluster?
(1,477 Views)
Nevermind.  (It was the mechanical action of some booleans inside).
(1,467 Views)
Hi paul_cardinale,
it's because of latch Mechanical Action on your + and - buttons of the control. Change those to "switch" type and the Value property node will change to the cluster data type.
More info here:
Why is My Boolean Value Property Node a Variant?
Hope this helps,
EDIT: Sorry, didn't see you resolved it on your own 🙂
_______________________________________________________________
-Patrik
CLA || CTA
If it helps - Kudo it, if it answers - Mark As Solution
(1,458 Views)
Classic. 🙂
Qestit Systems
Certified-LabVIEW-Developer
(1,454 Views)
