Y Controls Version 1 - Ready for Guinea Pigs
Y Controls are an alternative to X Controls and Q Controls.  This table illustrates some of the differences:
Unzip the installer.  Read the ReadMe.  Run the installer.
If you're curious, look inside the source.
Message 1 of 21
(2,379 Views)
Maybe not.  I'm finding newly introduced bugs.  Stay tuned.
Message 2 of 21
(2,329 Views)
OK, throw away that other one and try this one.
Message 3 of 21
(2,300 Views)
I've made some minor improvements.  Is anyone interested?
Message 4 of 21
(2,253 Views)
We're watching!
Message 5 of 21
(2,228 Views)
A few images or a PDF would help greatly in judging whether one should give it a whirl or not.....
Message 6 of 21
(2,215 Views)
Indeed.
I glanced over it.
A big reason for QControls is the inheritance of control properties. If you create a string child, you inherit all the string properties. That's the entire set property for the entire control class hierarchy is implemented with VI class methods .
At a glance, YControls seem XControl based, and they don't have this ability. That is a huge downside.
I couldn't tell at a glance how\if you solved this.
Message 7 of 21
(2,207 Views)
wiebe@CARYA wrote:
Indeed.
I glanced over it.
From an instance of a Y Control (which is a cluster) on a front panel, the (only) visible element is an instance of the Facade.ctl.  You can right-click on that cluster element and create a reference, property node, or invoke node to access all the methods and properties of the facade.
There is an XControl hiding inside Y Controls; but it's just a helper used to capture certain events, it doesn't impose it's limitations on Y Controls.
Message 8 of 21
(2,200 Views)
How about this.
Message 9 of 21
(2,198 Views)
That chm for me looks empty. I see the index, but it shows nothing where the actual documents should be.....
Message 10 of 21
(2,188 Views)
