Cluster resize problem
     I have a cluster of knobs, which shows the user some values according to the selection of rows and columns of the user. whenever the user selects the rows or columns the front panel of the vi adjusts the cluster accordingly, The problem is that is goes top of the screen eveytime and if i'm using the vi as child vi it exapnds when user uses Mouse down. So how to get rid of the exapnasion and how to make the cluster vi to be center everytime of creation. The expansion of the vi stops when panel is resized first.
(3,272 Views)
Go to VI Properties and under Window Appearance, Window SIze and Window Run-Time Position, you shuld be able to change the settings to achieve what you want
Doug
"My only wish is that I am capable of learning each and every day until my last breath."
(3,236 Views)
  sorry, it doesn|t work.
(3,212 Views)
Did you use specific values vs Use Current Panel Size?
Doug
(3,209 Views)
