Clusters break when changed. How do I plan for future growth of clusters?
Clusters look like they can be used to "future proof" what gets passed to a sub vi.
But they break too often, and are not flexible enough.
Is there a "software engineering" solution to making them more future proof?
How about using arrays inside of clusters?
Just skip clusters, and pass references?
What's the best solution?
Chris
(3,816 Views)
Accepted by Chris_in_Colorado
Make your cluster a type def.  It is an option under customizing a control.
Lynn
(3,813 Views)
Lynn
And here is a Nugget to go with that topic.
Ben
(3,786 Views)
Thanks for the replies folks.
But do Type Def suffer the same problem that Globar variables do? They are hard wired to a file. Which means any subVi using can't be truly portable
with a group of programmers. (I use universal shift registers that are 100% portable, but they're weird).
Message Edited by Chris in Colorado on 08-03-2009 02:13 PM
(3,773 Views)
Define "Truly portable" Type-defs are a blessing when working ina group development environment. I shiver at the thought of doing group development with them.
Q: What is a "universal shift register" ?
Ben
PS Please concider marking Lynn's reply as the solution since he replied first. The best I would get is an "assist" (still in hockey land) You can un-mark my post as the soltion using the "options" located in the top right corner of that post.
Message Edited by Ben on 08-03-2009 02:23 PM
(3,765 Views)
USR are the trick where you use a shift register on a wire inside a while loop that runs once, but do NOT define the starting value.
The subVI retains the value between calls = hence a true global.
Great for Write-Once-Read-Many variables like Serial Number, IP address, etc.
(3,756 Views)
OK now I see.
USR = Un-initialed Shift Register also known as Action Engine.
I use Type-defs with them as well (see the nugget linked above)
Ben
(3,749 Views)
