Code written for LabView 6 cannot find SubVIs when run in LabView 2013
I am reworking some code that was originally written for LabView 6.1
There are quite a few SubVIs that the program was not able to locate when I launched the main VI:
AI Config
AI Start
AI Clear
DIO Clear
Continuous Pulse
Counter Start
Counter Stop
quite a bit more.
In searching the NI site for these, I come across articles referring to these SubVIs so I am wondering if this is something I am missing OR something that was renamed in later versions of labView.
Any guidance?
(3,000 Views)
Those vi's are from the traditional DAQ(Legacy)  palettes.  DAQmx has surplanted traditional DAQ.  (Years ago!)
You should strongly consider migrating the legacy program to modern methodologies using DAQmx- it is well worth the small investment.
See Also
DAQmx FAQs
and Transitioning DAQ to DAQmx
(2,995 Views)
Thanks, i figured it was something of the sort...
(2,988 Views)
