TO DISPLAY MESSAGE
hi
I am doing a project with labview, where a provide the user three cases. Now in one case I provide a limit to the user. I want to display a message for 15 minutes warning the user if he is over the limit. If he goes within the limit I want the message to stop else give an output of 0 when the time overruns. How do I do this. How do I display this warning message and give it a time limit.
(3,099 Views)
You can display a pop-up box with the VI in the Dialog palette.  If that's not what you need then post your code as your problem description is kind of confusing.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,092 Views)
Donajacob wrote:How do I do this. How do I display this warning message and give it a time limit.
Make a subVI of your own.  All it would need is an event structure to look for the user pressing the Ok button and then have the timeout be however large you need it.
(3,074 Views)
